need feed back and picks
ozz
i just put my mp3 struts on and awr 21.5 mm sway bar/
i have ground-control coilovers on and its bouncie as hell/ how far down are your coilovers and did you cut the bump stops/ do you have to get an aligment after putting them on
next
doe's anybody have any really good picks of the swaybar installed
is yours noisy and last how did you decide how far to put the endlinks in for daily driving(inches or what)
I think the end link's can't be extended out past 5/8 in. Mine are a little more than half way out front and rear. Anything past that and you will loose the end eye-bolt. (This happened to me.)
Check out these pic's. They should help. As far as noise, the end link's are, how you say, NOISY AS F#CK!! Not much can be done to keep them quiet except turn up the radio.
http://www.awrracing.com/pages/projects/dgpr52.html
Patrick
