need a little help.
fuglymonkie
MSP
most likely there is a thread on the forums to tell me how to do this but its 3:24 AM. and i tried to take out my hot pipe for the side mount but it won't come off. i've loosen the two screws but it won't come off. what am i forgetting to do? any help would be greatful.
And you can always try using a little silicone spray, or something like that.
P.S. -- The correct subforum is your friend. Thread moved. ;)
Make sure the clamps that hold the pipe onto the turbo housing are completely off. Also make sure that the Intercooler side of the hot-pipe is seperated from the intercooler itself. Now, with your strong hand under the kink and your weaker hand down at the turbo housing, simultaneously pull up (might take some umph) while twisting. You can try pulling the pipe back while you're pulling up to unseat the pipe on the turbo housing lip. If all else fails, you can try running the car for a bit to heat up the plastic, but be sure to wear gripper gloves if that's the case.
thanks i was able to get it off using a blow dryer and a lot of pulling. ended up hitting my self when i got it off. no bloody lip lol. now i'm able to fix it thanks for the help.
