cougar10agREDUX
- 2003 Protege ES-T
hey, so finally got around to installing the WOT box. install was pretty easy 6 wires. Just make sure you go by the ECU pinouts given in the directions and not wire color since the same colors are reused in the ECU harness. also i'd recommend wiring the clutch switch at the ECU since it'll be easier. it was a PITA trying to reach the wiring at the clutch switch its self.
also so far i haven't gotten a MIL and i've had it in for 2 days
here the website for more info
http://www.n2mb.com/
Here's some videos.
2-Step Inside.
http://www.youtube.com/watch?v=zBv6Iw5ZQ9Q
2-Step Outside
http://www.youtube.com/watch?v=Ov8aikMp7xM
WOT Shifting
sorry about the quality, hard to drive with one hand. But it was holding about 5-7psi through the shifts
http://www.youtube.com/watch?v=MunqlwD18GU
Here's some videos.
2-Step Inside.
2-Step Outside
WOT Shifting
