My low beams and fog lights don't work.......help?
Kaze
So I had this small issue..one of my headlights stopped working. No big deal, just replace it right?
Today I decided to investigate and see if swapping bulbs from left to right would further pin point my problem. The bulb is actually fine and it works.
So then now I think it's an issue with the ballasts. I took my working ballast and put it in the headlight that doesn't work. Theoretically it would work, yes? But it did not fire up. So then I put that working ballast back to it's place and now my other headlight won't fire up...
So I inspect the other ballast and find out there is actually water dripping from inside of it..(wtf). I'm like okay, I guess I need a new ballast and need to seal my headlight better. I put everything back to figure out now my fog lights don't work now. I don't know what the **** is going on, now both of my headlights don't work and now my fogs. The only way I can see at night is if I use my high beams (which still work, along with the corners).
Do you think I possibly messed my working ballast up when I tried to swap it with the ballast that had water in it? I don't even know how to go about this problem. My friend says I may have blown some fuses and he will take a look at it later. I guess I need a whole new HID kit (it's the original kit from the factory...could I just buy an aftermarket d2s kit?) and replace some fuses...?? Any input guys?
