If you want to buy the parts you'll need: Oil pan gasket, Main bearings, I would go ahead and do the Rod bearings, Timing cover set, I'd do the Timing belt too since it needs to come off to pull the crank, that should pretty much do it. You don't HAVE to pull the crank but it does make it a bit easier
