Well thanks for the obvious backlashing. My bad for misspelling a word.
As for the hinged strut bars.
I researched and wrote this myself. So overlook any spelling or grammatical errors.
ok just think of your suspension as a trapezoid.
Now the top two corners (Red dots) on either side are where the struts mount to the car and the top line is the strut bar (blue line).
In a effort to keep things stiffer, people put strut bars to make sure they trapezoid stays in perfect shape thus reducing frame flex, body roll and overall rigidity.
Well with a hinged bar you are allowing those top two points to move up and down as well as flex left and right. The hinges do what hinges do best and that is permit movement.
The hinges allow each strut tower to move more free without translating much force to the other strut tower and wheel.
With a fixed bar, both towers are connected with a ridged bar that will transfer the forces acting upon it to the other tower. This will do the thing a strut bar is meant to do.
Just because a strut bar is bolted onto a expensive car or made of carbon fiber, it does not mean it is effective.
Copied from
TuningLinx
On most applications, strut bars install in minutes and they look shiny and cool. However, looks have little to do with performance. To reduce the flex between struts, the setup should be as rigid as possible. In fact, real strut bars don't have joints and look like an "X", so go for it for a more rigid frame if you have time and money.
Hope this clears a few things up.
