My clutch is messed up, HELP!!!!
Snooky chill man! The test pipe has nothing to do with your flywheel! Your gonna be fine. IF they try and say s*** then get those guys from t he shop to go fight for u. If you go to mazda usa you can see the after market clutch and stuff so im guessing the stock ones will be cheaper then that.
i hope, thanks man!
they would only be able to void warranty on parts that failed BECAUSE of the test pipe. i know thats the law in the US anyway...the test pipe could NOT have caused this issue.
I know the test pipe has absolutely nothing to do with the issue...but you know how dealerships can be sometimes.
Snooky, don't worry about it. They will most likely not notice it's there.
I GOT HER BACK!!!!!!!!!
it took 4 ever but i finally got it. the new clutch is so much better, smoother, and the shortend the friction point for me, so that its not as high, and when other people drive it, it wont stall. they gave me no problems thank G-D!
they did tell me thought that the tires are seriously worn down, i gotta stop racing...
thanks for the help guys!
Yeah, that was how mine was when i got it back, felt a whole lot better, clutch was easier to work, it was great. it didn't last long though mine went back to normal eventually, hope yours lasts longer!!!
thanks bro!
good luck
