My ABS issue.....................
herbieP5
Contributor
The issue is I dont want ABS. I need to know if there is someone that knows an easy way to disconnect them. I know I can pull the fuse, but then the ABS lite will come on. I am also worried about effecting other cercuits. If the only way is to pull the fuse, then can somebody tell me which wire to snip to turn the DAMN lite off.......
some on must have an idea or two......
Pull the fuse
Pull the cluster
Pull the bulb
BOOM DONE!
DON'T CUT ANYTHING!:eek:
that easy huh..............I am not gonna screw anything up that is gonna say, i dont know, make me hit a tree or sumthin......................
Not unless you lock the brakes and slide into it.:D
