mazdaspeedwerx
- 03.5 msp
anyone have any troubles with thier msp running extremly lean at low rpms?
Puckpimp71 said:BS... no such thing as a lean MSP
mazdaspeedwerx said:anyone have any troubles with thier msp running extremly lean at low rpms?
If your foot is off the gas and you are coasting in gear, the engine doesn't need any fuel. I think the ECU might even completely cut off the fuel injectors in this situation. This is normal. If you press the throttle even the slightest bit, it should go back to hovering around 14.7 AFRmazdaspeedwerx said:yes I am running a narrow band a/f but at like 3500 rpms the gauge bottoms out and stays untill I hit the gas
this is pretty much the same thing happening to me. the only mods I have are a mbc 3" exhaust and a cai.I'm going to put a adjustable fuel pressure regulator on tomorow see if that fixes the problem.MrDiggler said:Sure it can happen. I can tell from my dyno pulls that I get scary lean below 3750 rpms. I've also noticed a nasty stumble that occurs sometimes going uphill under medium boost and light load and below this rpm, and I attribute it to an overly lean condition. The DSM AFC is my next mod.
