KyRaceFan said:
flow @ 36psi fuel pressure.F2TNYC said:
mx3ownzj00 said:flow @ 36psi fuel pressure.
yep, and at WOT its around 45-48psi I believe. they are able to flow between 280-302cc max, but I wouldn't push them too far past 280cc or they'll just go static.LinuxRacr said:Raise the fuel pressure, you get more flow thru the injectors. I thought the stock fuel pressure was about 36? (huh)
mx3ownzj00 said:yep, and at WOT its around 45-48psi I believe. they are able to flow between 280-302cc max, but I wouldn't push them too far past 280cc or they'll just go static.
the numbers aren't adding up but for all practical purposes they are just 280cc injectors than can flow a lil bit more if pushed far enough. mazda(freak)
well Mazda has spec'd them at 280-302cc. i'm not sure that idle fuel pressure is for sure, maybe it is in the 4x's.F2TNYC said:listen you cant flow more fuel than the injector size....how did you people come up with this 302cc on a 280cc injector at 36psi????you get more fuel volume not more fuel once you play with the pressure....damn.....usually the fuel at idle is like 40-44psi and rises like 2-4psi with the rpms with 4-6 being the max to compansate the demand for fuel at higher RPMs...
mx3ownzj00 said:well Mazda has spec'd them at 280-302cc. i'm not sure that idle fuel pressure is for sure, maybe it is in the 4x's.
KyRaceFan said:What kind of 320's are you getting?
Swapping the injectors for larger ones with no modification to the ECU is a little missguided. Do you have plans to do the ECU Maps as well? Here is a shot of the EIC-2, it is quite inexpensive and will add the extra fuel you need without ******* up your car with oversized injectors. Do as you like, just thought you might like to research this thing out as it's a marginal solution to your fuel problem...F2TNYC said:the pressure can be correct but the size is only one....anyway i just wanted to make sure what size is it, next weekend i will be upgradinf these injectors in favor of 320cc to accomodate the raised boost..thanks for your help...
http://www.sdsefi.com/eic.htmlKyRaceFan said:Brian, whats the total cost for the EIC? Website?
I'm looking for something to add fuel so i can run more boost, and probably a 50 shot of nitrous.
Please consider doing your internals if you are planning to run over 10Psi. On Page 156 of Maximum Boost there is a chart that has Boost Vs. Compression over Octaine... Although you can use 15 Psi on this engine in it's stock form, you will need to run 115 Octaine all the time and even with that, I doubt that your SMIC will be able to handle the "Paint Stripper" that your T-25 will become.KyRaceFan said:positive rep left... its gonna come down to extra injectors or nitrous.
50 shot single fogger... or extra injectors and 15psi daily.. hmm.
