Msp help???
mazdaspeed protege
I just blew my motor last week ago so i swap a new one and just got done finishing it today so when i went to go fire it up and it fires but it would not start so i think there is no fuel goin in to the motor so i check the fuel pump and there is no gas comin out of the fuel pump so is there any fuse that can cause this?????
thats gonna be a hard one to diagnose. how did you test the fuel pump? Does the engine turn over? Do you get any CEL's?
look in the fuse box under the hood, then look on the label inside the fuse box. It should tell you where the fuse is, but if it worked before I don't see why it wouldn't work now. Did you plug up all sensors?
