MSP ecu on custom turbo kit
nealric
Carless :(
I have a custom turbo kit coming soon and I am looking into engine management for it.
Eventually, I will be going full standalone- probably haltech, but I would like to get something just for starters that would make the turbo out of the box ready to go without any tuning.
So... has anybody run a MSP ecu on a custom turbo kit as their only means of fuel management. If so, how did it go?
I will be running a small IHI turbo with a cast manifold and small front mount intercooler. Shooting for 6-8 psi and 160-180hp.
Did a search, but couldnt quite find enough info.
azian6er ran 283whp on his thumper kit with nothing more than his stock msp ecu for the most part.
yes im 1 using MSP ECU
172WHP Dynoed with 9 PSI using WRX Small Turbocharger!
I have Walbro Fuel Pump & Stock Injectors.
All Proteges that have 2.0 Liter engine have same Fuel Pump & Injectors.
If you want 6psi Safe Level with MSP ECU you will be ok.
protegeracer02 said:
so no new fuel pump or injectors??? just stock protege + msp ecu?
