Msp Ecu For Boost
JAmazan
2001 Mazda Protege ES
hey guys
3 quick questions for u about the msp ecu.
1. If i boost with this ecu, do i still need an fm clamp
2. if I boost with this ecu will i need a fm unit
3 anyone has one of these ecu laying around that i can take off ur hands
You shouldnt....
The purpose of the clamp is to keep the ecu from recognizing that you are trying to add fuel and leaning things out.
The fm is there to add fuel to the mixture.
The MSP ecu should already adding the right amount of fuel for moderate boost.
and you may want to try the msp section next time instead of the protege5 section. but no you shouldn't need any of that as long as you stay at a low boost.
oh ok...if someone can move this to the msp section, would be appreciated. also what size injectors are the msp
