lmfaoBlkZoomZoom said:All new cars turn the compressor on when in defrost and footwell. This is done to run the air through the evaporator to de-humidify the air so it doesn't fog up the window or get the carpets wet........duh.
I'm prefectly fine with it, it works for me. But it's a simple fact that R-134A is about 30-40% less efficient for heat transfer than the old R-22 in home AC, let alone R-11 and R-12. The systems are just designed better to compensate.wicked said:oh and R 134-a isn't that bad for cooling
every other option is ether devistating to the atmosphere,or deadly flamable
and it aint about the tree huggers.our atmosphere is only 21% oxygen,and 1 hydrocarbon atoms will destroy over 1,000,000oxygen atoms.so if you like to breath you will respect thier choices to use R 134-A.
Glowmunkey said:I'm prefectly fine with it, it works for me. But it's a simple fact that R-134A is about 30-40% less efficient for heat transfer than the old R-22 in home AC, let alone R-11 and R-12. The systems are just designed better to compensate.
