MS6 Camshafts, any opinions??
not personally. just curious, unless your planning to go fully forged internals to run bigger turbo/higher boost... why get just the forged camshaft?
I was planning on going fully forged, but not for a while. I just had not seen these at all, and hadnt heard of anybody having them. However, I am about to slap on a 3076R in December.
im curious, if the boost stays the same is there any real point in getting a bigger turbo???
just because its the same boost from a bigger turbo doesn't mean there aren't gains. the bigger turbo will be much more efficient and will still flow more air at same boost levels and since it will be more efficient it won't heat up the air as much as the stock turbo at the same levels.
good to go, so there is an advantage!
sorry if it seemed like i was trying to bash i was all in all just curious i had thought about that same thing the other day while driving and thought to ask here since he mentioned it. :-P
ok no more hijack lolz thanks for the answer tho!
Thanks for the explanation. I was curious about that as well.
