Ms3 rims on cx5 (stupid noob question)
mech_e
'15 CX5 GT
any problems fitting ms3 rims to a cx5? I found a good deal on cl, and like the look. I want the least pain, so don't want to mess with spacers. They're 18's with 215/45s on, will I be able to get a winter tire that is similar in size to the stock 19's?
I think there is a member on here with them on his. I believe he ha spacers to keep them looking tucked in.
There is no problem if the 18" rims that you're looking for are one of these:
B45B-V3-810 (gunmetal) or 9965-22-7080 (aluminum)​
Here are some examples of members here that use them:
The bolt pattern and offset is exactly the same as OEM CX-5 and there are no spacers to worry about. Simple!
The compatible tire size to get for them would be 225/60R18.
The part number for the center caps are: KD51-37-190
Thanks for all the info! They are from the 07-09 ms3, so it looks like they have an offset of 52.5mm instead of 50mm. I'm not too concerned if they stick out am extra eighth inch in either side
