See if BC Racing has coilovers for the MS3. They are on-par with KW's and much less expensive. SRT-4 crowd loves them and they beat the s*** out of their rides. I have KW's on my Neon SRT-4 and they are great, but BC seems to be the shiznit now. I'm keeping my MS3 stock for now as it's the "family" car... with a cutting edge...
They do, and no, I assure you that they are NOT.
Put both your BC dampers and a set of KW dampers on a shock dyno, and compare the results to one another. I think you might find the results surprising.
Without any real data to back that up, I'd be hesitant to make such a claim. I'm sure the BCs work fine for most ppl but companies like KW, H&R, Koni, Bilstein have built a reputation by making some of best struts/coilovers for a wide range of vehicles for quite some time now. This has been proven whether in a lab setting under shock dynos as well as on real world motorsports racing of all types.
Up until I got my MS3, I've never even heard of BC Racing. It could just be me being ignorant but the names that instantly pop up in my head when I talk suspension are almost always those 4 companies I mentioned earlier.
OK, I will stand corrected on my terminology. "on-par" doesn't mean "equal". I'm sure if you beat the snot out of the BCs, they will break faster. When tried over a specific range on various pavements and settings, the KW's have a better longevity, and engineering, and warranty. I run KW's on my SRT4. I haven't used the BCs yet on any of my rides, just going with what other SRT4 owners claim.... Hence my "on-par" claim relating to an SRT4. Perhaps they suck on an MS3... totally different car..... for which I will stand corrected.
par (pr)
n.
2. An equality of status, level, or value; equal footing: a local product on a par with the best foreign makes.
...and for that matter, each to his own.
I just can't justify buying a setup that isn't properly engineered specifically for my car (when it's being marketed as such), and I've never seen any data to back up the claim that BC has done their homework and put out a product that has proper valving for the spring rates that they've chosen. I also tend to shy away dampers that use "clicks" in their adjustment hardware, especially when they don't provide shock dynos for their individual dampers upon request...
Like I said, each to his own. BC coilovers have their place in the market, but that place is not on my car.![]()
Do you plan on doing any sort of coil overs or shock work?
Eventually, yes.
If I didn't have a ridiculously expensive wedding to pay for next spring I probably would have already done something, but I honestly can't decide if I'd rather go a little more hardcore and get the Mazdaspeed Coilovers or just buy some good dampers. If there was indeed a truly GREAT damper option right now I probably would've already gone that route...
Honestly I wanted to go with a really expensive setup like the HKS or K&W. But the problem I found was trying to get camber plates that work with them without jumping through a lot of hoops. No one on here had done anything like that and when I asked SU for info they just said they had no info on the topic. So along with my lack of money this made me chose the BC's since they came with the plates. Later on if I turn my MS3 into a track car and I strip out the interior and everything I might upgrade to a better setup.
Not to sway from the topic but on the street, you'll probably be hard pressed to out drive either set of coil overs. For the average back road burning Joe, it's probably 6 of one, half dozen of the other.
I don't agree.
The experience of driving a car with a dialed-in setup that has proper damping curves for the application is markedly different from the experience of driving the same car with a "budget" setup that has little more than "ride quality adjustment knobs" (which is what I call the knobs on most adjustable dampers) that pretty much only adjust rebound.
