MS3 cabin air filters change out...my hints
fasteract
2008 MS3 GT
A couple of things I noted after watching the great YouTube instruction video..as mentioned elsewhere you might want to disconnect the battery. I didn't..got a bunch of air circ. motor recycling when I disconnected the harnesses from the fuse panel and then a DTC on start up after finishing..P0606 I believe. Had a ScanGauge to clear luckily..not sure if that code would self erase eventually. Video mentions taking off lower harnesses from fuse box only..more room to move fuse panel obviously if you remove the uppers.
The white panel to access the filters has a grey rubber seal cord which runs out of its groove to the outer lip through 2 slots..mine dislodged so make sure it's in correct position before remounting plate/cover. The top front screw is difficult to replace. I attached it to screwdriver with reversed masking tape to get it started.
A drop lamp with the low energy flourescent bulb gives good light without turning an already tight spot into a sauna or giving a nasty burn if you lay on it.
Like others found it unnecessary to remove trim strip/glove box. Video also didn't mention the black plastic plug holding carpet to the fuse panel bracket..needs removing to fully clear bracket.
