MTBjunkie00
- 2009 Mazdaspeed 3
Took the car in for new rims/tires and an alignment before winter. The tires/steering wheel shimmy very hard now above 65 (doesn't go away at higher speeds and isn't present at lower speeds).
The car used to have a slight left pull and pulls hard to the right now. Alignment sheet from the shop here. I've searched around the forum, but couldn't find a definitive alignment spec for an '09 speed 3.
Any help on my situation or official spec sheets would be greatly appreciated. Thanks all.
BTW, I switched from a 215/45/18 to a 235/40/18 if that helps at all. Stock suspension.
