I've been kicking the idea of building a motor up, money is an issue, but I do receive a discount on parts, but honestly don't know much about car engines, have raced motorcyle engines for a long time and would like some help deciphering the order in which I should mod my car financially.
The list I have so far would look like this (Please correct or make suggestions)
Double Platinum Plugs (not sure if has these stock yet)
Light FlyWheel
Light Pulleys
Port & Polish Intake On Block? (Not sure if this is necessar on a car)
New Intake
New Exhaust
Larger Fuel Pump
Adjustable Fuel Regulator
Progammable Ignition
Wide Band Oxygen Sensor
New Cams
Larger Turbo
Larger Injectors
Two Fuel Rails
Two Fuel Tanks
Nitrous
ReGear 1st-4th for good 0-100mph time, leave 5th for street use.
Forged Rods & Pistons
Hemi Head (If Possible), If not polish & cut head.
New Transmission with Sequential Gearbox
I'm sure I missed a lot of good ideas, like I said don't know much about car motors. Your help greatly appreciated. Suggested products by part number and manufacturer GREATLY appreciated. Also any shops that have specialty with the Mazda Speed motor or a motor that could go in there that is even better to start with.
Thanks,
Rob
Light FlyWheel
Light Pulleys
New Intake
New Exhaust
Larger Fuel Pump
New Cams
Larger Turbo
Larger Injectors
Two Fuel Rails
Two Fuel Tanks
Nitrous
Thanks,
Rob
