Miata Trouble shooting
Tommy267
2000 Mazda miata
I was driving my car with no problem, went to the store and when I went to leave and it wouldn't start I initially thought the fuel pump went out because I didn't hear it prime and so I replaced it and nothing so I ran a hard wire to it and it wouldn't crank after that so I checked for spark and nothing. All fuses and relays are good but I cannot figure it what's causing. When I go to crank the check engine light usually comes on then it goes away when you crank it but now it's not coming on, idk if that helps or not.
If you have a manual trans, Is the clutch switch ok?
If you have an auto trans, is the brake switch ok?
