My car started this a long time ago. It probably has been close to six months now. In the past year or so I have replaced all struts and springs, the control arm bushings, the end links, the sway bar bushings, the front motor mount, the side motor mount, and both front hubs and bearings in attempt to return this car to like new condition.
However, there is one noise that still really pisses me off. A damped metallic pop from the front of the car that occurs when I am backing out of my driveway and my steering wheel is turned to the right. It also happens backing out of parking spaces and such as long as the steering wheel is turned to the right and I am backing up. Unfortunately, it is not consistent. It hear it probably less than 50% of the time I leave my driveway and to varying degrees of loudness.
It was incredibly loud tonight though since it made it all the way until my back wheels went down the curb before it popped. If it pops when the car is level then it is much more subtle.
The only things really left are the rear and tranny mounts, the tie rods, control arm ball joints and the axles, but I am not sure how any of those could be the culprit. I can drive as hard as I want, accelerate, brake, turn and everything seems pretty solid. I can do figure eights until I throw up, but I can not reproduce the popping noise on demand.
I understand the hopelessness of trying to diagnose a mechanical noise from a forum post, but I am at the end of my rope, so figured it was worth a shot. It was many years ago when I couldn't solve the engine ticking until someone on here told me to check my exhaust manifold bolts, so maybe I will get lucky again.
Thanks in advance.
Thanks in advance.
