mazdaspeed3 thermostat
slo4now
08 mazdaspeed3 bright red
Im a nubi here so i dont know if im asking a dumb question or not.
I was wondering if they sell a colder thermostat for these cars, if i
can get away with a 20deg colder themostat and not throw off any
engine codes that is 20deg less IAT = more HP.
Need help.
Trying to go with the least expensive boltons first, do they even
make an aftermarket thermostat for these cars yet? 160deg would
be really nice and then im buying the cai.
CAUTION!!!
If you go with a cold thermostat you will increase engine wear!!!!!
Engines today have very tight tolerances, unlike old 1950-1980 cars. If you go to a colder thermo, the metal in the engine will not contract and remain expanded, increasing friction thus increasing wear!!!!
Don't do it!!!! That trick only works on old school engines!!!!
Engines run more efficiently if they are hot or at least at nominal operating temperature; especially with todays EFI systems.
This car runs rich. Lowering the temp is going to make it use maps to run even richer. Last thing we need.
Some vehicles - my old V8 Dakota comes to mind, benefit from this trick. The Speed3, I don't think so.
MBC means manual boost controller. He said the cheapest gains. Good luck installing though. Can be a dangerous mod if you just blindy turn up the boost though. (naughty)
Cai and downpipe should give safe noticable gains but cost more.
Color me confused for the second time in as many days.
I respond to a question on thermostats and get a lecture on MBCs?(confused)
prolly a bad key stroke and bounced into diff thread thingy i've heard its happened to others
Well you quoted me on post #7 and said something about lowering engine temps and your dakota kinda made you look like you dont know about mbc's(crazy)
Whenever I think of a colder stat, the first thing that comes to mind is LS1s. God I love those motors...
I don't think a 180* would really kill us that much from a 190*. I'll leave it up to someone else to figure out how it works.
