I recently installed torque and I haven't been able to find a theme that I was happy with because I wanted it to match the interior. So I decided to make my own theme. The Dev will be uploading the Speed 3 and Speed 6 Themes this weekend so you can install it through the Torque App. The Speed 3 theme has two modes (night and day), if you would like to auto switch between the two themes you can use Tasker (link below) to automate copying the files back and fourth at a specific time of day. If you need help, feel free to PM me. The themes will not have the mazdaspeed logo if installed through the theme server. If you would like the logo, follow the instructions below.
Tasker - https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm&hl=en
2007-2009 Mazdaspeed 3 Theme
Day
Night
Mazdaspeed 6
To install, extract the zip file to your Androids SD card replacing the files in the \.torque\themeDir folder. The two PNG files are the gauge backgrounds, you can use Tasker (see above) to automate copying the files back and fourth from the Day/Night folders to switch themes. You can set it to switch based of the light levels. It really isnt hard to do but its confusing to explain. If i get a lot of questions then i will make screen shots.
NOTE: I have been having some issues with the external PIDs dropping out completely so I have to keep re-adding the gauges, has anyone come across this? Thanks
Day
Night
Mazdaspeed 6
