Mazdaspeed 6 badge removal
RobbyMS6
2006 Mazdaspeed 6
I'm in the process of removing the badges on my car (hairdryer and fishing line) and i removed the mazdaspeed 6 badge and i was working on the Flying M and felt it stop at one point. I assumed that meant that there are pins there. How do i fill in those hole? Better yet, how do i remove it?
Beyond Bondo -- why not just remove the flying M repaint it, Please use the search function, put it back on? Or turn the flying M into a batman symbol? Just in case you are not excellent with body work.
...only if you wanna damage your trunk.
Front can be removed with the badgeless grille, rear can be removed with fishing line and heat.
And, as before, search through and you should be able to find all the answers your looking for.
do you have to pull it out with the fishing line or just slide it across like I did for the mazdaspeed logo. Im pulling like mad and the thing wont come off.
if your looking to remove the "flying M" then if you pop open the truck there are those button type things if you get a flathead screwdriver pop out the middle part of it and pull them all out then the trunk liner should fold down.
once you did that, locate where the badge is on the outside and just match it with the inside and you will see 2 very small pins-type things holding it on. unscrew those and then do the fishing wire thing.
I got it thx. I was just trying to pull them out from the wrong spot (underneath instead of on the sides).
