Mazda6 high idle problem?
duckdive
Model: 2004 Mazda6S
Duration Owned:1 year
Mileage:49,950 (50 miles of warranty left)
Mods:K&N air filter
Fuel Octane Used:89
Problem: Idles over 2,000 RPM when starting
Conditions Under Which Problem Occurred: Always after sitting for a day min.
Steps Taken to Address Problem: taken to dealer, they claim it is normal
Resolution of Problem: none
Current Status: Sitting apart at dealer as they are replacing 3rd gear synchronizer and shifting fork and some other transmission issues. Last month it had the recall work done where they flashed the CPU and replaced the fan control mod. Also they replaced the starter because it would make a rearing noise when starting. I had complained about the high idle prior to this recall/warranty work. They claimed to not be able to be able to simulate problem. I took the car to another dealer and they also couldn't find any problems. I went in and showed them the transmission issue and the high revs. The mechanic made a confused face when the RPM was a bit over 2000 but the intake guy claimed it was normal. My question to him was if this is normal why had it never done this before 2 months ago. He explained that it will do it to warm the engine up in the winter or when it has not been driven in a while. However, again, it never did this last winter or after sitting for up to a week. I don't think this is normal but i don't know what to tell them to replace to fix the problem, that is if its a problem. Is this a problem? i have heard that the mazda supercharged cx-7 will do this but my car is not supercharged and it has had the K&N filter the whole time I've owned it. Can someone please help. Thanks
Yeah it does go away when the car is warm. I am just confused as to why it only recently started doing this. Is there any possible explanation about that?
thanks
i have an '06 3 five door and mine starts up in the morning and idles at 2000 then slowly drops to about 850 after about 40 seconds. It is completely normal. Even if it just started.
My '07 MS6 does this each and every morning, but drops to normal. This is pretty standard for any vehicle that is fuel injected. Mine seems a bit more "pronounced" if there has been a big temperature swing overnight.
