its at the front of the engine. black cap with a silver bolt in the middle.
you will need an oil filter wrench (76mm) and 1/4 Allen Key. basically what i do is loosen the nut with the allen key, turn the cover two full turns, then remove the bolt, let the oil drain, and then remove the cover the rest of the way.
