Mazda Rx-8 Hydrogen Rotary!
Antoine
Administrator
MAZDA RX-8 HYDROGEN ROTARY ENGINE: A SPORTS CAR (AND ENGINE) LIKE NO OTHER
Mazda RX-8
Source: Mazda
Mazda Unites Alternative Fuel Power and Zoom-Zoom
DETROIT With a cat-like predatory stance, forward-thinking freestyle door system and enough room for four, not two, adults to enjoy all its benefits, the Mazda RX-8 has set itself apart from the pack. But if the recently introduced RX-8 production sports car truly is unique thanks, in large part, to its rotary engine, the RX-8 Hydrogen Rotary Engine (RE) concept, showcased this year at the North American International Auto Show (NAIAS), takes "unique" to all new levels.
Featuring a fuel system that consists of a high-pressure hydrogen tank, the vehicle balances the needs of the driving enthusiast and the environmentalist with a blend of alternative power and the exhilarating driving experience for which Mazda is known.
As the auto industry turns its attention to hydrogen fuel as a gasoline alternative, the RX-8 Hydrogen RE offers a hydrogen-powered version of RENESISMazdas next generation rotary engine that was introduced last year in the all-new RX-8. By virtue of its smooth performance, compact size and impressive driving characteristics, RENESIS was named International Engine of the Year in June 2003.
The RENESIS Hydrogen RE allows the RX-8 concept to run on either hydrogen fuel or gasoline and capitalizes on all the advantages of the rotary to assure RX-8s ease-of-operation and reliability.
The RENESIS Hydrogen RE incorporates an electronically controlled hydrogen injector system, with the hydrogen injected in a gaseous state. The system draws air from the side port during the intake cycle and uses dual hydrogen injectors in each of the engines twin rotor housings to directly inject hydrogen into the intake chambers.
Because it offers separate chambers for intake and combustion, the rotary engine is ideal for burning hydrogen without the backfiring that can occur in a traditional piston engine. The separate induction chamber also provides a safer temperature for fitting the dual hydrogen injectors with their rubber seals, which are susceptible to the high temperatures encountered in a conventional reciprocating piston engine.
Also helping to maximize the benefits of the rotary engine in hydrogen combustion mode, the RENESIS Hydrogen RE features adequate space for the installation of two injectors per intake chamber. Because hydrogen has an extremely low density, a much greater injection volume is required compared with gasoline, thus demanding the use of more than one injector. Typically, this can be difficult to achieve with a conventional reciprocating piston engine because of the structural constraints that prevent mounting injectors in the combustion chamber. However, with its twin hydrogen injectors, the RENESIS Hydrogen RE is both practical and able to deliver sufficient power.
In addition to the revolutionary hydrogen-powered RENESIS rotary engine, the Mazda RX-8 Hydrogen RE concept benefits from improved aerodynamics and optimized tires and weight-saving measures. A fast-fill tandem master cylinder reduces brake drag and friction hub carriers help cut power losses.
The vehicle also incorporates a host of other technologies for exceptional environmental compatibility. Three-layer, wet-on water-based paint on the RX-8 Hydrogen RE dramatically reduces the emission of organic solvents, saves energy by shortening the drying process and reduces carbon dioxide emissions. Moreover, the plant-based plastics used for the vehicles interior parts provide an attractive alternative to plastics derived from fossil fuels such as petroleum.
The Mazda RX-8 Hydrogen RE illustrates Mazdas dedication to the future environment without abandoning true Zoom-Zoom and soul-of-a-sports-car thinking.
thats great... way to go mazda... only problem now is where the hell can you get hydrogen to fill up??
thats what they are tryin to work out, the cars were nothing to build, its refueling them cheaper than gas or right at gas cost..
the hydrogen RX-8's are JUST beginning to be available for commercial lease in Japan... it'll be awhile before it becomes available outside of Japan, if ever...
btw, the engine in hydrogen mode only makes 109hp..... yeah.....
hydrogen with out a doubt... the cost is already cheaper then gas. its the cost of converting stations thats really holding us back. Well that and certain people still have oil to sell.
Much safer, it ignites at a much higher temp then gasoline and is 14times lighter then air. If its were released into the air it would quickly go off into the atmosphere. People have to remember that the hindinburg (sp?) was not due to hydrogen.
Better than a Protege! (rlaugh)
yep, wasnt it a high concentration of oxygen??
Many things acutally...
hydrogennow.org said:
[font=Arial, Helvetica, sans-serif]The Facts on the Hindenburg Disaster: [/font]
  1. [font=Arial, Helvetica, sans-serif]The bags of hydrogen that provided the lifting force for the Hindenburg were NOT the main contributor to the fire. The surface of the ship was coated with a combination of dark iron oxide and reflective aluminum paint. These components are extremely flammable and burn at a tremendously energetic rate once ignited. The skin of the airship was ignited by electrical discharge from the clouds while docking during an electrical storm. This reaction has been proven chemically for years, and was demonstrated with actual remnants of the Hindenburg sixty years later, which burned as vigorously as on the day of the disaster. [/font]
  2. [font=Arial, Helvetica, sans-serif]The hydrogen burned quickly, safely, above the occupants. When the escaping hydrogen was ignited by the burning skin of the airship, it burned far above the airship, and was completely consumed within 60 seconds of the ignition. During this period of time, the airship descended to the ground from the 150-foot docking tower. [/font]
  3. [font=Arial, Helvetica, sans-serif]Almost all deaths were caused by jumping or falling from the airship. Of the 35 deaths from the disaster, 33 were caused by jumping or falling. Only two deaths were caused by burning, and it is likely that those two were from proximity to the burning skin of the airship, or from the stores of diesel fuel that were ignited by the covering. Whereas the hydrogen burned within one minute of ignition, the diesel fires burned for up to ten hours after the ignition. [/font]
  4. [font=Arial, Helvetica, sans-serif]The Hindenburg would have burned if it had been filled with inert helium gas. Even if the Hindenburg had not been lifted by hydrogen, the ignition of the covering would still have happened, and would then have set ablaze the diesel stores, resulting in the same disaster. [/font]
  5. [font=Arial, Helvetica, sans-serif]The main cause of the disaster was pilot error. The only way to prevent the disaster would have been if the pilot had chosen to land in better conditions elsewhere, which was very feasible, considering he had had enough fuel remaining to reach all the way to California. [/font]
