Mazda of the Month - ENTER NOW for May!
Status
Not open for further replies.
Antoine
Administrator
Welcome to the Official Mazdas247.com "Mazda of the Month" Contest!
* The MOTM is OPEN to ALL Mazdas! *
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.
ENTRY RULES
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* If you become a MOTM winner, you may not enter the same Mazda again until at least 12 Months after the month you had won. However, if you own several Mazdas, you are welcome to enter those as well * Each Member may NOT enter more than one Mazda per MOTM contest * Previous MOTM winners who wish to enter again (after 12 months) must enter with all new photos of their winning Mazda
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247.com Community
ENTRY REQUIREMENTS
* Each contestant must submit three single high-quality high-resolution images of their Mazda. One image must be of the exterior, another the engine bay and finally an interior shot. Compilation style shots (multiple images within a single image or picture size frame) are NOT ALLOWED!
Format
1. Username
2. Name
3. Model name + (Year)
4. ONLY 3 Images (one exterior + one engine bay + one interior shot) NO ATTACHMENTS PLEASE!
5. "Mod" List *Please make your list CLEAR & CONCISE!
Entry Tips
* Wash & Wax
* Clean your interior
* Clean your engine bay
* Choose an interesting location
* Choose a well lit location for photos
* Make sure your interior shot is clear and detailed
* Make sure your engine bay shot is clear and detailed
Example (Obviously, this is NOT my Mazda but for the sake of an interesting example):
Antoine
Antoine *
Mazda 767B (1989)
Performance Mods:
600hp 4Rotor
Exterior Mods:
Aero tuned for the track
Interior Mods:
ALL BUSINESS
Stereo Mods:
4Rotor
Awards Won:
Second in awesomeness only to the 787B
Recognition:
Raced at Le Mans...Helped lay the groundwork for the 787B which won Le Mans in 1991.
PRIZES
* A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
* Your Mazda showcased on the Mazdas247 Home Page!
* 5% off any Speedcircuit.net purchase made that month!
VOTING RULES
* All voters must have a postcount minimum of a 100 posts. The only exception to this rule is for MOTM participants who are also new members
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247.com will result in immediate disqualification *If you are disqualified, your entry & poll listing WILL remain but your votes will be removed. Everyone will see that you broke the MOTM rules
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
Please note the following rules!
  • If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
  • If you become a MOTM winner, you may not enter the same Mazda again until at least 12 Months after the month you had won. However, if you own several Mazdas, you are welcome to enter those as well * Each Member may NOT enter more than one Mazda per MOTM contest * Previous MOTM winners who wish to enter again (after 12 months) must enter with all new photos of their winning Mazda
DEADLINE to ENTER is May 27th 2012!
PRIZE UPDATE!
From now on, MOTM winners will receive...
2003.5_MSP
Patrick
Mazdaspeed Protege 2003.5
Performance MODS:
POPE DP
custom 3" exhaust
Drilled/Slotted Rotors
Exterior MODS:
S204 lip lip
ISport CF Rear window Spoiler
Maxspeed Lowering Springs
Debadged Trunk
DIY Retrofitted 8k HID W/ audi style LEDS
Smoked Side repeaters
Smoked Reverse/Rear Turn Signals
Interior MODS:
Trim pieces painted black
Glowshift under radio bezel/wrapped in black plaid
Glowshift Boost/Vac gauge
Glowshift Exhaust temp gauge
Glowshift Oil pressure gauge
Now that yellow super stock is not something you see very often. airbox and elbow. You're in kokomo????!!!!
its not super stock lol i have a full exhaust thats it....waiting to put in my fmic with hardpipes (at dads in ohio)....doing appearance mods now as its cheaper (except full exhaust lol), and i do live in Kokomo..
I see the exhaust. I guess I was mainly pointing out the engine bay :)
Joka1
Rob McCord
2002 Mazda Protege ES-T
Exterior
Interior:
Engine Bay:
Performance Mods:
-Fully built motor at 8.1 compression- Pauter Rods/ Wiesco Pistons/ Bored .20 over/ ARP Main Bolts/ Clevete Bearings
-T3/T04 Turbo
-Perrin Intercooler
-Turbo XS Rfl Bov
-Tial Wastegate 8 PSI Spring
-Mpi Tuner EMS w/Turbo Module
-NX N-tercooler system
-550 Injectors
-2 Extra 440 Injectors
-Ceramic Coated PG Intake Manifold
-Custom ADJ Cam Gears
-MAM Tubular Manifold Ceramic Coated
-Custom 3" TurboBack Exhaust w/ Magnaflow Muffler
-Greddy Profec B EBC
-Exedy Stage 2 Clutch
-Fidanza Flywheel
-AWR Deep Sunk Baffled Oil Pan
-Greddy Full Auto Turbo Timer
-Custom Turbo Pipes
-Hose Technique Turbo Couplers
-Weapon-R Engine Dampner
-AWR Front/Rear Motor Mount
-JIC A2 Coilovers
-KMR Lower Tie Bar
-GT Spec Front Strut Bar
-VTTR 6 Pot BBK
-VTTR Stainless Steel Brake Lines
Engine Apperance Mods:
-Dg Carbon Fiber Engine Cover
-Polished Valve Cover
-Custom Hood Props
-GT Spec Strut Bar (Ends Ceramic Coated/ Middle Black)
-Custom Radiator Shroud
-Hose Techniques Blue/Black Vacuum Line Kits
-Chromed Turbo Compression Housing
-Blue Top Optima Battery
-Cut Valve Cover to Show Cam Gears
-Blue Radiator Overflow Can
-Custom colormatched show washers
-Custom Optima Battery Box
-Aero-Catch Flush mount hoodpins
-Hella Supertones
-Speedcircuit Thermostat Outlet Kit
-Apexi Diverter Plate
Exterior Mods:
-Full Msp Front End Conversion
-DG Front Lip
-Buddy Club 2 Side Skirts
-Buddy Club 2 Rear Bumper
-VIS C/F Hood Custom Painted
-Vis C/F Trunk Lid
-EVO 8 Spoiler
-DG C/F Grill
-DG C/F mirror covers
-Tinted Sidemarkers
-Piaa 540 Foglights
-18" Enkei Sesto Rims
-5% Tinted Windows
-JDM Style Headlights
-AAC Bumper Brackets
Interior Mods:
-4 Point AutoPower RollCage
-Reapulstered Backseat W/NX bottle Mounted in the Center
-Autometer Phantom Wideband A/F Guage
-Autometer Phantom Boost Guage
-Autometer Phantom Pryometer
-Autometer Phantom Volt Guage
-Autometer Phantom Oil Pressure Gauge
-Autometer Phantom Tempature Guage
-Autoguage 3 Guage A-Pillar Pod
-Forcefed Modified Steering Wheel Pod
-Forcefed 2 Guage Cluster Surround
-Adj Shiftlight
-Bride ERGO Blue/Black Front Seats
-Sfi Certified 3" 5 Point Racing Harnesses
-Reapulstered Door Panels
-Dyed Headliner
-Nokia Blue Shif Knob
-Nokia blue Racing Pedals
-Sparko Black Suede/Leather Steering Wheel
-Blue Led's Under Each Seat
-C/F Covered NX Arming Switched
-DG C/F Doorsills
-Corksport C/F Guage Surround Overlays
-Custom Molded Stereo Surround
Stereo Mods:
-Compustar Alarm
-Kenwood Indash 7" Touchscreen
-7.2" Rear TV
-Audiobahn Immortal 10
-Phoenix Gold Amp
-JL Interior Speakers
2011 Awards won:
-May 11: Mazdas247 ROTM
-Jun 11: Forum Fest- Best Mazda
-Aug 11: Remix Car Show-Hottest Mazda
-Aug 11: Remix Car Show-Best Display 3rd Place
-Sep 11: MazdasNW End of Summer Bash @ Corksport- Best Display
-Sep 11: MazdasNW End of Summer Bash @ Corksport- Most Carbon Fiber
Rob
Man so many big players when it's warm out. I should do mine during the winter :)
he definitely has a very well done car but, I just can't get myself to vote for it though. Not committing to anyone's entry until the time to vote is here.
Status
