Mazda Connect Firmware 74.00.230A (now .324A)
Status
Not open for further replies.
send me a DM indicating what region and version you are looking for and I will help you out
Hi @anyDude , I need the latest firmware 74.00.310A for my 2016 Mazda CX-5, currently on the firmware version NA region 70.00.100A, can you please help me with the latest file link? Is it ok to go directly from 70 to 74 upgrade?
Please note the OP has directly copied my files in his first post, but I can not amend it.
There has been a change in what Version Numbers to now Install and this depends on what Version is currently running in your Mazda today.
Install Procedure...
(All Mazda Models already on Stage 2 .up firmware in use).
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW
55.00.600 NA N for North America, or,
56.00.000 EU N or 4A N for Europe/UK , or Australia, Asia, NZ, Oceania Middle East.
LIKE 31.00.100 or 41.00.000 or 55.00.000 (NA N) or 56.00.000A (EU N or 4A N).
THEN YOU MUST UPDATE with Version Number 70.00.100A First!.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
70.00.100A-FAILSAFE.UP (First)
Then next Install (one after the other do not remove the USB Flash Drive).
70.00.100A-REINSTALL.UP (Last)
Warning...!!!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL use YOUR ''CONNECT'' in CAR FOR A FEW MINUTES, THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION TO INSTALL.
Next you MUST do final and last below.....
Your FINAL Install Procedure is now Only a 1 (one) File Installation...
(All Mazda Models with .up Firmware use)
IF YOUR MAZDA HAS .up FIRMWARE VERSION ON or ABOVE
55.00.650A
(NA N) or the 56.00.100A (EU N or 4A N) or 58.00.310A
or Any 59.00.502A or 59.00.650A,
or Any 70's Firmware like 70.00.021A, 70.00.100A or 70.00.110 or
70.00.150A or 70.00.335C or 70.00.367A or 74.00.230A or 74.00.311A
THEN YES YOU CAN UPDATE Directly to 74.00.324A for LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY,
MUST USE EITHER ONE of...
NA N_74.00.324A-UPDATE.UP (North America ONLY)
or
EU N_74.00.324A -UPDATE.UP (Europe/UK)
or
4A N_74.00.311A-UPDATE.UP (ADR, AU. NZ, ME, Asia) (74.00.324A 4A N (ADR) is not yet available)
THIS IS THE LATEST GENUINE FIRMWARE CURRENTLY AVAILABLE
FROM MAZDA JAPAN As Of December 30th, 2022.
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...None, DO NOT ASK.
YOU MUST PURCHASE and INSTALL the TWO GENUINE MAZDA PARTS LAST.
DO NOT INSTALL THESE NEW PARTS FIRST or BEFORE ANY 70s FIRMWARE OTHERWISE YOU WILL HAVE TO REMOVE THE NEW PARTS RE-INSTALL THE OLD PARTS AND THEN START AGAIN.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
Warning...!!!
55.00.650A
or
or
Thank you for laying this all out, super helpful and informative! I'm looking to update my 2018 CX-9's firmware to help with stability. I'm having a random reboot issue and am hoping updating the software will solve this.
Hi everyone,
I'm looking to update my 2017 Mazda 3's firmware to the most recent update (74.00.243 NA). I already have the hardware from the dealer. Can someone DM me with the file?
Thank you to anyone who can help out
Hey there everyone. Ordered my upgrade kit from Mazmart the other day and will be here this week. Upgraded from 55.x to 70.x with no issues. Looking to upgrade to 74.00.324A NA. Thanks for the help!
Thanks for the post @ASH8 , super helpful
I bought a kit but didn't realize the firmware would be so hard to find.
Are you able to send me the file?
@ASH8 Appreciate you helping everyone here. I'm getting ready to retrofit carplay into my sister's 18 mazda 3 and I myself have a 21 miata that could use the 74.00.324 North American update. It would put my mind at ease having the latest firmware. Thanks
Look IF YOU MESSAGE ME, START CONVERSATION AND ASK.
You must have a few posts in forum first, so we get to know you.
Click on my Avatar, then Start Conversation.
Hello ASH8,
I’m looking for the latest firmware update for my 2020 Mazda 6 in North America.
I’m currently running firmware version 70.00.352 NA N, with failsafe version 70.00.352
Please let me know if you may assist me.
Thank you for your help in this forum and for giving users the means to upgrade their firmware outside of going to the dealership! Thanks again!
Yeah, my wife just wants her touchscreen to stop having ghost touches and for the backup camera to consistently work. I was able to get my hands on 70.00.100A and got that updated this morning. Still looking for whatever the latest NA version is for this (2017 Mazda CX-5)
@ClssicCaleb i did the update from 70.00.100A to 70.00.335C on my CX5 2016 a couple of months ago and worked fine.
I had no issues with ghost or camera, my issue was that CMU rebooted in cold weather, but sw update did not help, it was the SD map card causing the issue, had to take it off.
Good to hear and funny you mention that. Ash8 is super awesome and got me going with the firmware, but on another note while I was trying to backup the navigation SD card it was painfully slow and kept failing.
I used win32diskimager to make a backup image of the card and luckily it was able to read it and make a block level backup. I restored that image onto a newer SD card and it's night and day difference now with speed and loading. So maybe that will fix some other quirks.
Not sure what happened here. I attempted to update from the current version to 70.00.367A and it all stopped, wouldn't do a thing. It says Fail safe not available and won't find any update file on the USB stick, it previously found it. The unit still appears to work as it should but I want to complete the update.
After reading a post by Ash8 it looks like I should have updated to 70.00.100 first which was the two part install.
Any help will be massively appreciated.
Status
