Mazda 626 MPS
Make Mazda
Model 626 MPS
Engine Location Front
Drive Type AWD
Weight 3042 lbs | 1379.9 kg
Engine
Engine Configuration V
Cylinders 6
Aspiration/Induction Turbocharged
Displacement 2496.00 cc | 152.3 cu in. | 2.5 L.
Valves 24 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 280.00 HP (206.1 KW) @ 6500.00 RPM
Torque 289.00 Ft-Lbs (391.9 NM) @ 4000.00 RPM
HP to Weight Ratio 10.9 LB / HP
HP / Liter 112.0 BHP / Liter
Bore 3.33 in | 84.6 mm. | 0.1 m.
Stroke 2.91 in | 73.9 mm. | 0.1 m.
Transmission Information
Gears 5
Transmission Manual
Seating Capacity 4
Exterior
Length 181.101 in | 4600 mm.
Width 70.901 in | 1800.9 mm.
Height 55.501 in | 1409.7 mm.
Wheelbase 102.801 in | 2611.1 mm.
Brakes
Front Brake Size 345.001 mm | 13.6 in.
Rear Brake Size 315.001 mm | 12.4 in.
Tires / Wheels
Tires Front : 235/40 ZR 18
Rear : 235/40 ZR 18
