Mazda 6 short Ram air intake install ??
zo6om
Hello evry one
i have Question about install short Ram air intake for mazda 6 modile 2003 2.3 L 4 cylinder
and what about thmoved original air filter better removed complet or remove front panel only to install short Ram air intake Policher
plz help me with picture when u can
thanx
i can barely understand what you wrote so...
heres how i installed mine.
took off the stock airbox, remove the gold/bronze metal piece, and loosened the bolt on the frame that the support piece of the intake pipe will line up with.
i stuck a screw off the airbox into the vacuum hose, put in the intake, tightened it down, and it was good to go.
if you disconnect your battery your going to have to reset your windows.
