mazda 3 / ms3 headlights?
mattj3636
2008 Mazda Speed3
i tried searching, didnt really come up with a solid answer, so sorry if this is a repeat..
but i was just wondering if the mazda 3 headlights are the same as the mazdaspeed 3? as in, would mazda 3 headlights just bolt right up and fit perfectly? and are the actual circles on the inside the same?
i dont really see how they could be considering everything in the front end is different between the 2 cars. the hood, fenders, and bumpers are different
i believe that the mazda 3 coupe headlights are different then the mazda 3 hatch.
with that said. the mazda 3 hatch headlights and mazdaspeed 3 headlights should be the same.
the reason im asking is because im gonna order an angel eye halo kit, and the company says its for the Mazda 3. and idk if itd work, so prtty much, not the whole assembly itself, but rather the circles on the inside for the halos?
i can see a little variation in the sedan's headlights (middle), but not between the ms3 and the mz3 5-door
if you are doing angel eyes, the ones for the 3 and ms3 should be compatible. the inner rings are the same size.
