- 2003.5 Laser Blue Mica MPS
I`m trying to figure out exactly how to hook up 1. volts 2. vacuum and 3. brake fluid temp. gauges on a Mazda 3. Does the brake temp. need to be hooked up at the stock sender or somewhere else? Is there one or two wires on the stock sender, which one? Vacuum would go to any good vacuum source goin into the head? And is there a best/easiest place to read volts from for a gauge? Are there ECU wires I can tap into? If so, pin #s and wire colors would be greatly appreciated.
EDIT: Oil Temp. nothin to do with brakes, sorry... oil temp., volts, vacuum
