map of grounding points
FL_PR5
2002 Mazda Protege 5
Was wondering if anyone had a photo or diagram that mapped out the stock grounding points or the points used in the 1sty grounding kit? Plan on making a kit and would like some diagrams to base measurements off of, without tearing up my engine bay. thanks in advance
I don't have that kit but here's my flow. Body on passenger side close to power steering reservoir to motor mount stud between mount & motor then to the valve cover bolt on rear corner on pass side then to intake manifold under one of the vacuum mount bolts then to a bracket bolt in top rear side of tranny then splits - one to the negative battery terminal & one to the mounting bolt in the body for the fuse/relay box. All 4 gauge wiring. Sorry, not diagram tho.
thanks, i appreciate it. i have pretty much the jist of it down. but there were like 14pts on 1stys kit, could be more, but that's how much I counted. Would just be easier if there was a pic or something, my wires are about done on my car (bang)
There is a how-to about installing the 1st grounding kit. It has pictures of all grounding points as well as measurements of all the wires.
However, all that is really necessary is replacing the factory grounds, and the power wires to the alternator and fuse box. Anything else you add is just for looks.
yea, i know there are some dimensions, but not all. i may have overlooked some parts, guess i'll skim through it again after lunch.
