dadasracecar
So a few of us installed manifolds this weekend. Two of us had DNP manis and one person had the PG. Here are some side by side shots. It appears that the tubes of the PG are significantly longer than the DNP. Welds are nice on both. The bracing is significantly different. The DNP is noticeably heavier than the PG despite the longer tube length. This may be due to the larger bracing or material type.
The DNP has the black painted flanges. It appears that one manifold bolt hole is not used on the PG manifold. This is apparent in pic 3.
