MAF Sensor Voltage
I have the pinout sheet form the protege ecu but I believe its from a non mp3 so I do not know if the voltage is the same between two different ecus. Well any it show in manual that with ignition switch ON the voltage ranges from .9-2.0 and at idle it ranges from 1.7-2.4, so I dont know what voltage is at WOT but if somebody could find out that would be great.
Omar
Kissimmee
