builthatch
my car has an eibach pro-kit. a couple years ago i installed eibach 15mm spacers. i also had my rear fenders rolled to a reasonable angle at that time...i am still rocking the OE 215/45 tires almost 3 years later.
i know a 225 tire would only be a 5mm increase on the outer portion as it would relate to my fenders, but to me it seems like it'd be too close and/or rub on both the front and rear or def the rear.
225 and 10mm spacers would be the same difference as what i have now, but i can't go to 10mm spacers because i do not want to change the wheel studs. as it stands now my eibach spacers are the system 4 units that have the studs built in.
how do i figure out if this will work? measuring and stuff i don't think will cut it because of the dynamics during suspension compression.
here is what i'm dealing with currently - it's pretty close to flush
