Low Wiper Fluid Warning
MidwestCX5
2015 Mazda CX-5 GT AWD w/ Tech
Is there anyway to disable the low wiper fluid warning message? When I click the info button on the steering wheel the message goes away, but it turns back on 20 to 30 seconds later. This warning is helpful, but it covers the entire info display and will not turn off until the wiper fluid is filled. Any tips?
This should be fairly benign since it is just a connector but if it bugs you that much you could disconnect the washer fluid level sensor. Possible ways I am not aware of to gain access to the sensor.
A big job though according to FSM though...
WASHER FLUID-LEVEL SENSOR INSPECTION
1. Disconnect the negative battery cable. (See NEGATIVE BATTERY CABLE DISCONNECTION/CONNECTION [SKYACTIV-G 2.0, SKYACTIV-G 2.5].)
2. Set the front over fender aside. (See FRONT OVER FENDER REMOVAL/INSTALLATION.)
3. Set the mudguard (RH) aside. (See MUDGUARD REMOVAL/INSTALLATION.)
4. Remove the front bumper. (See FRONT BUMPER REMOVAL/INSTALLATION.)
When this switch has continuity it means fluid is low. A broken connection means there is fluid.
Actually...I just looked on mine and all you would need to do remove a few screws from the bottom plastic splash shielding on passenger side right below fog light. I can see the sensor from the bottom of car. I went in this way when I swapped my fog bulb for an LED.
