lots of black smoke
03spicyspeed
msp#1648
well when i get in to third and give it about half throttle it starts to miss and smoke really bad. its unburnt fuel i know that but it only does it at 3000 to 4000 rpms and if i floor it it wont do it or if i let off the gas a little and fall out of boost it stops smoking and shuttering so i dont know wut it could be. i changed the plugs and there is no cel
could be fuel cut/boost cut depending on how cold it is by you right now. also could be a small boost leak. Had that happen to me the other day
I think it's a MAF leak, there muyst be a leak somewhere in the charge opiptes. You should try relocating your MAF, that way if there is a leak or you pop of a charge pipe no serious damage occurs just the car gets slow.
well found the problem it was the nipple that the bpv is conected to on the hot ic hose so ill have fix it or get a front mount ic
You could always glue it, a lot of people have glued it as a temporary option that last forever it seems.
