- 2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
if you are making hard enough left turns that your oil light is coming on, you are more than likely starving that last cylinder of oil. this is why some companies make baffled oil pans. sadly we're not lucky enough to have one quite yet. i would refrain from doing those types of turns unless you want to spin a rod bearing like my brother did the exact same way on his car. that will pretty much leave you with the option of buying a new or used engine.
