normandy2013
Hey folks so I have an 03.5 MSP Engine with ~185k on it. For some reason I burn oil and lose a lot of oil. Every 1 week to a week and a half I need to add 1 full quart of oil. I recently changed my valve cover gasket, and thought for sure that I would not lose any oil. I do see a lot of oil around coilpack#1 and some on the front lip of the valve cover.
I am happy that my boost is much more stronger and the compression is tight
I pretty much own the highway !
Right now I am running super lean for some reason, there seems to be no vac leak. But I do have a problem pumping my gas in. The gas pump would stop every 5 dollars in. I am assuming The charcoal canister is bad! Some mornings the inside cabin reeks of fuel any ideas?
