I have a 2012 Skyactive HB i GT that I got the wife. I added some wheels but it needs a drop bad.
Before...
After...
The issue is that it seems from everything I have read is that the sky active is particularly light in the nose compared to all the other cars as you can see in the photos stock the nose sits a little higher about 3/4" compared to the rear. I was going to get some Racing Beat springs because I heard the drop is minimal and that the ride is good. BUT they drop the rear MORE than the front and with this model that just won't do.
So any suggestions on a spring that drops the FRONT more than the rear and will maintain as close to a factory ride as possible?
Seems that most manufactures have not taken into consideration yet that the SA's have a lighter front end... Most springs I have found look to be designed for the heavier 2.5 and speed cars.
Thanks in advance!
Before...
After...
Thanks in advance!
