List of Useful Mazda2 Guides/DIYs
OZCorolla_x
Swiftly
2009 MAZDA2 NEO 1.5lt Auto 5Door JMODE10Y1901426XXX. 204,200km
OBD2:
Mazda2 DE 1.5L OBD2 PIDs
mazdas247.com/forum/t/mazda2-de-1-5l-obd2-pids-before-and-after-throttle-body-cleaning.123880650/
Mazda2 DE 1.5L OBD2 PIDs Before and After Throttle Body Cleaning
ENGINE:
mazdas247.com/forum/t/XX
Guide: DIY 2009 MAZDA 2 DE 1.5lt Replace Sparkplugs - Coming Soon
mazdas247.com/forum/t/diy-inspect-cleaning-mazda2-1-5l-zy-ve-vvti-oil-screen-filter.123882638/
Guide: DIY Inspect & Cleaning the 1.5lt ZY-VE VVTi Oil Screen/Filter
Guide: DIY 2009 MAZDA 2 DE 1.5lt Replace Rocker/Cam Cover Gasket - Coming Soon
Guide: DIY 2009 MAZDA 2 DE 1.5lt Replace Timing Chain Tensioner - Coming Soon
Guide: DIY 2009 MAZDA 2 DE 1.5lt Replace Sump Gasket - Coming Soon
mazdas247.com/forum/t/relocated-mazda2-ecu.123859728/
Guide: Relocated Mazda2 ECU
Guide: DIY 2009 MAZDA 2 DE 1.5lt RHS Top Engine Mount Replacement - Coming Soon
Guide: DIY 2009 MAZDA 2 DE 1.5lt Rear Engine Mount Replacement - Coming Soon
COOLING SYSTEM:
mazdas247.com/forum/t/2009-mazda2-de-1-5l-auto-coolant-choice.123882633/
Guide: Mazda2 DE 1.5L Auto - Coolant Choice
mazdas247.com/forum/t/diy-mazda2-de-1-5l-zy-ve-coolant-change.123882634/
Guide: DIY MAZDA 2 DE 1.5lt ZY-VE Coolant Change
BRAKES:
Guide: DIY 2009 MAZDA 2 DE 1.5lt Replace Front Brake Pads - Coming Soon
Guide: DIY 2009 MAZDA 2 DE 1.5lt Front Caliper Slide Pin Re-Lubrication - Coming Soon
Guide: DIY 2009 MAZDA 2 DE 1.5lt Replace Rear Brake Shoe Replacement - Coming Soon
Guide: DIY 2009 MAZDA 2 DE 1.5lt Replace Rear Brake Wheel Cylinders - Coming Soon
SUSPENSION:
Guide: DIY 2009 MAZDA 2 DE 1.5lt Front Strut Changeout - Coming Soon
Guide: DIY MAZDA 2 DE Lower Control Arm Bush Replacement - Coming Soon
Guide: DIY 2009 MAZDA 2 DE 1.5lt Rear Shock Change Out - Coming Soon
STEERING:
mazdas247.com/forum/t/2011-mazda2-inner-tie-rod-end.123869553/
Mazda2 Inner Tie rod end Removal
TIP: Get & use this tool, means you don’t need to Remove the Rack from the Car
Guide: DIY MAZDA 2 DE 1.5lt Steering Rack Change Out - Coming Soon
BODY External:
Guide: DIY 2009 MAZDA 2 DE Headlight Replacement - Coming Soon
Guide: DIY 2009 MAZDA 2 DE Fix Water into Spare Wheel Well - Coming Soon
mazdas247.com/forum/t/jdm-mazda2-demio-headlight-upgrade.123855955/
Guide: JDM Mazda2/Demio Headlight Upgrade
BODY Internal:
mazdas247.com/forum/r/mazda2-de-factory-keyless-entry-retrofit.41/
Guide: Mazda2 (DE) Factory Keyless Entry Retrofit
Guide: DIY 2009 MAZDA 2 DE Replacement Key Programming - Coming Soon
mazdas247.com/forum/t/2011-mazda2-diy-head-unit-android-4-4-4-install-tips.123852443/#post-6420913
Guide: 2011 Mazda2 DIY Head Unit Android 4.4.4 Install Tips
mazdas247.com/forum/t/mazda2-de-factory-cruise-control-retrofit.123868046/
Guide: Mazda2 DE factory cruise control retrofit
mazdas247.com/forum/t/cargo-cover-parcel-shelf-broken-lug-repair.123873062/
Guide: Cargo cover / parcel shelf broken lug repair
If you can recommend any "Additional DIY's" or your have written one, then post it into the Main Mazda2 Forum.
Admin will review the "Additional DIY's" and add them linked from this Thread.
Thank you for your help.
Rob
