builthatch
i am eternally anal regarding my vehicles...
the yesterday i heard a pebble hit the roof of my ms3 while on the highway. i knew it probably left a mark, and sho 'nuff, it did; a small chip with a baby chip next to it. whenever i get a new car, such as with my ms3, i always get a body shop contact of mine to mix up some matched Glasurit base so i can touch up little things that pop up. this particular problem didn't respond well to the plain 'ol touch up paint, so i figured i'd go ahead and put some clear atop it, and then wet sand.
i work with plastic scale models, have a pretty good artistic feel, etc, AND, since this was on the roof, i figured i'd have some leeway because hoods and roofs typically have the most clear on them due to gravity when painting during production. so i went ahead and did my thing. the first round of toch up clear and wet sanding of the spot (2000 grit) came out pretty good, but it needed a hair more clear to fill it up just a bit more and make it totally sealed and flush. so i went ahead and put another layer on, and left it overnight to set. i come out in the morning, it's cured as planned, and go to wet sand. after i'm done, i go and hit it with some compound by hand and notice that all around my spot, about 1" diameter, is a hair darker than the rest. turns out i freakin' broke through the factory clear with the paper!!!!!! interestingly enough, i wasn't that upset because i knew that whatever resulted at this point, would mean no more chip, so, despite the hassle and cost, it would be back to perfect. but i DEF learned a lesson about doing this type of thing on a silver car...
so i passed my favorite body shop enroute to easter b-fast, and sure enough my guy is there, on easter sunday, hanging out doing some side work. i show him the spot and he tells me the best way to handle it, to make it perfect again, is to sand it down, blend in some base, level it, etc, and then re-clear the entire roof. the design of the ms3 roof makes it a pretty easy proposition, since the roof is a pretty seperate deal on this car due to the roof side gutters, etc. he assured me it'll be mint and he's always done me good so i went ahead and scheduled for 4/2.
it was a hard lesson learned, but atleast there was a problem there that was out of my control in the first place which will be resolved properly because i made it worse haha.
