Another year on the road, another Warrant of Fitness check passed
Car is running well but does need a bit of work, which might be the plans for this winter:
-Battery needs replacing and there's a slow drain somewhere in the system
-Rear swaybar bushes are shagged again
-Steering rack makes a horrific clunk at low speed - everything underneath is tight and sound so it might be a rack replacement job
-Still have a stumble under boost above 1/2 throttle, might change to Toyota coil-on-plug units to see if that helps?
Other than that it's still going great!
