Konig Hypergram 15x7.5 35ET + 205/50/15 Continental ExtremeContact Sport
DE GX
Bought the wheels from GWR in June. Didn't get around to put some tires on them in October. (toetap)
As a bit of background info, the car is riding on the stock 4x4 suspension, and (as you can see in the pictures), the tires are 205/50/15 Conti ECS. I have also previously installed some camber bolts up in front, so there is a bit of negative camber (~-1.5 to -1.6). No fender work has been done on the car, and from a combination of regular street driving + a full day's worth of dry and wet autox-ing, I can confirm that there is zero rubbing at all.
pEiVDl7W9oFf0ct-O02hi9bJdk4j0jA33qmRl5U65Of5ZUzdjdEKpT7tnbGAsZQqmQS1v0Hz2yMtpib8c_bth3TuSh3SanSkK8rKPIUPqjY23zAwiEYWTa2LdpgOBqb9XdJDVN8Uj6jG2cxKujJN0cneXzP6qAKbVDPeS55fAHIc-UIMaoYFdKhwia-OjikIqQBFg8H0bEgyM_IxRP_PcFSc4U3QicKw4L35uyjdE-LG_p87L5vmEQzVfG0OjBRFkGuy-sToHbA567aOzpWirl6TOZhUuWLsclzwoX8Xd1gz-erIVBrWA2L0VhNd8PxM_dfmHZAh1r87o9xjeds9dgHYA89LJz1WXQZBQm6ipl57XX4KIsHI1qNfe5qdS6jaiDTHsIkyQUBpZ6tpoJG2Drc3Y6v0c0tWOL0VrAYtP5zEWRvKJ15MzUB_Ah8tFLOnMohm43PEgBeM7joeoruBZ4nNYmOsOuqQANwoDZ5-b8OguAxyWkbez0mciLagL-_CqAcH1eRh3CBqaaEFR3aThlKZGzd9iAffoFEaCJrWK443exbZxUL5jrJPNrbOecdoEgVURM_tvI0LJh238od-o9dftuY_cUFk7McSMvvohL6ERvwi2BYnP9DDwZGmpBxntZ864F2u567RaeCXYXMrichYAdfW0ePWOF5N=w800-h533-no
IYrahbmuxLnLicWRy85Z4uwzRRFkg4XQgbbpfRW5wDdejAvb5z2_R8VIuCnNVEQ9BmaMKN_msWtumB3uhDyj7VacP-CaQiEPJrrXykj3yQHGLR2q7tWhseJ2zXXyeIfGGpOLtjm7X6OxtyaeoaipFBznldOa2ckMIEZ7LfkO1Bhur8UMZdONj9hI7R8Nllkb1LnH7QUZ3NZLo5gtivxU7mGS0bWy2RLYa4KgCkE3o02kHyWT-4hcdVnETAztoX_AMLyaDIyXmv40Pw8x-rfZNmmGeFGj66SCpPAds-UmGxdKSvIghvSMtUjzusmL-aDNAOEwLOD8eiyQ31lF8VawUD99WxOyiA_SoBVzTNcg42l49TE-vb3ZNjYU0exbdvKvcn15sIj9Ecx81sg1LqR61w773hqfBSd81tO8CrrVk1YscOSdHu8VKqvTiib2abVk3Eav_YfvLm7JAoncBXUyA0_QI_LyvfZrdni_BeM_EHj4pFpDlaLUR5Kt33M_EqCvFmOPQgv03eWQRnhADPecS3x6LrhHkcVJmyWVsy8LU7ISIwk0D2uquTrVkyWkxf_AclH4zkB9iD_pBRF16dmIQqKE2gaKYng2H5L97BUANO1x2kje57sBzcLMLYMExF8wD9UwCMDWxCzCSFr_nQpZ8zHwc0kwb_MXLd-0=w800-h533-no
mNvuFCRstj88ArmdONwsCFYV7l90fgQ9SbdDujXBuDlI6ZWlx7TUTY4LOiK1bT4z7na35VGSFfL3XYARBdOPjAueVAUylLl4C17tHGqpPtljSh89JbYsnw79EXMjXirPhhVRNMiqOVIUUGFwYg-VEnjmzrn5frzAuD5DJupfb_zPBhyJxMQx5pX8N1tcin-y85IuPvSAJPitkkOttQ0OPo0vc-swzg8RAbAX966Fld-_0li9Ptq8YtLW7tQUFrWeCzSaoZa4qQOK-ecWWHfpFWLEe3HFoDI5-sKJZelfHyfKEh7P26rt9hv5KhJQNS5xKNhOelKwQqp_WHeeOfDtJnDhvYVyylysm0CXUNmeawj9CgpXKkDP4Yw1YyC5_By4Y1XDlWt0DeonXDS7rgLz8a8ZW0pEsWCa9PM16V0HqBoI07DKxLsnbLtRsAyieHUDy5oyPGngN2hSb9U6iqNrZxeUqlCeig9bMrfwihO2_doYRZKQmUQClk1dtFqfMamJe9EhzlKGJpd-DyjJ21ZvpCTbt6vaZadn5c_bLdFs8tW5GHJMbpVqYzJ9Oc0HipM1STubMSD-aEBfuDdIHSWExtQvX8l50FLg3L7IFBFhcWxDxtLlMVGx_tSUr1ocNpMAHwOVN1kVn9iWmOWvV4D30E5yzZ3_wfVCYrIO=w800-h533-no
From the photos, it doesn't seem like the wheel & tire package is sticking out all that much. In real life, however, I find them to be poking out more than the photos might suggest. In particular, with the wet fall weather we are getting here in the PNW, the extended wheel & tire package is kicking up a lot of fall/winter grime. My doors have been sprayed & coated with the typical fall debris now, and I would not be surprised to eventually see the door getting sprayed and chipped from road grime later down the line.
sy3RkrZ8caSObj8hQDVbfI0ilMa8c6Wqb_pK48kEauqXEOss1mdi5yAyN11vfPhMCBkH7SuBU8EqjFSsxK-2Omx_qUDsZt0WZQDpijeGAqgEUQJuzzKICf4hyy83FfrlWxMcSHjcfp1GRrhBc3EhR8pl9pzKW48Gk0NJPRjZk1lLOQO6r5X0uAGkR6Rl0TZCX5CvkpI4nouUiEXRn9_5Y79UCVTvjNZ4CU_a8PbMrjqbCvRs2JNcuYzjMmhBlRKYu6ruu47uAUNbGwbPXPR8oqY-ZeL84DVQX4GJo7tBt5EnEBrIXqyqEEJOwvuD5wfloHtX16bvXm-Yxbk6k3llODwe80ILSgYJyROxjGgvPzZIFuxqI8ATmPd5BbfqFKF2kVIxvgfDyIsQymeGvEE89g8stVylbhxkkqv1DgTQuhb-7AMAVDAQaNjfbYCxFszjaLNEyVCFu5SA6QP9xB6w8GSSvWNIGeokjaNvFu3MlgNe9cG9Wfs0EcC4DCsV9unhrDeghUPYhy7HAFs080qauDwzafomFH_Jukk_onEOODsTt_tiNDbm6B8c4LPtlz_vKhS6NjZuz6PJeGUFwik3MIdDaaBp7kb8UFhL2MOv85Hd9FQuiKQtx5FafZJGhWPGwDeLa_gLs6yRDxle4POAZT4sFaSaXLDmm5Nd=w800-h533-no
kpXWJDGnq0t2HXXtRIUifJ5ExYckl_DUWqI6QE5dhp6mqRrQt6NcPkrYhcBQagV24bO9h5qJhB9VqiytZ9olf_oD_l4eP0Zcq16ir8bt9F0B_Ac2F5GpAXVYGe5bhxwIddHjJ3Pv_ZwHHeLrE-IIV9A3ZnBvIVNFSNPnBBuLf2jmBjqsv-cZkfeJbx6qOYuxI0G3rlDtZDycz9fIriMwmVw-yrjcwFdp5nOE7KEhuuMKmvujW3EKSnKhPyzTzCWaNPnbV15Qu49XNHv_Tbp9q4mNw-2bUduLV9sokjdltqVvQAJN6TIxaFQI82tnt6UDfd99FKYtlWr4L8wdYOmvgyYqIn-jhZxRjxGd2GQoHq8RJVUmeEWPouTGfR9YEnuBO1ewL8pprzVMdXXFbqi047upyyE2JCe6ie0wjXrB3lRnd3sSSSy7ITQoXVno7cBuni6ORXu0yhzGY5joJ_WKYna0OjBp6xYAG-vafO8W-4tBKaMO0XHTW8i42N0hWkCxy81_K82WbahpoI04Mj6OaaG4PFXWJHBvMgXek3BFnKNGw7P29a1YpzoYy6GeoRqmMoYFChwO9Hnu3dqoJB4Ft2xLi4iKZtcfuI8TNotmn4hpFfEzuLi9A7QH7OOhL05hET9BlxQlE9vUPni8XWvG2yQYyE0ghUL5TTl7=w800-h533-no
In the ideal world, I would have preferred the offset to be a touch higher -- perhaps 38mm instead of 35mm. But a lower offset is good when it works.
The stock ride height makes everything look a bit ridiculous. I never noticed the wheel gap was this bad before with the stock wheels and tires (and the 20550/15 ECS are already supposed to be every so slightly taller than the stock 185/55/15 setup).
cUzIizsHpD_4q4jZGhWdy_1_Y4hSRlXbXEC7c7R6IlK7YLcUEOYTtrNdcaryGMjTJJ4Y8p-PhrD-Gb-mnNtMe_nK4i3f59JFTOASa1F8gLY-QwZqZsHHBxty7cOtsnRoxLh9pevEXbNC6GhDV3IbO4Izt2Uvr2wDjccK2oS1fGfdrga5p6GUHhKEag0VXkjbZtyZBbNucEQEIiw7z-lnM9xi3I3pwfe6FQCzXdC2baRRqWdNYQMArzcvBv_Of4tv4vbpuxumYS6cN5NCp7cWNXcX8p1GRh-13zjbkAOksTkuKlNYwow4RAuT3zs_XsVkEKuX-bJuHva_Eamjb7hKH1HLS82lPt2B6CJh4sfav1LnQCyT3Sn9P_Ez8USaIOBU67oiwjCMj0pAgOe37Ykeg3xE4SFSmlMsVgJ5Vh_s25eK4HLHZPTncapxSmE4rpL7sB8Jx6PAE8Oaukob7KHUWesGWRMB-aOQXOdvcW9Zizx5dO70GM3ZwupEvyrPBwfH__jseVkmUu4ZNGSt3_lLRGaRYSy5tri8vSJilwujKXeay95tt8UBYMU8g4hhVXPrcr7ttR5zUwLXB2_eXf7zXJ3rT8IF6xyRnIpIE6Bx6VuUTEtCz61sW9O5H2OCMgZOp3hxsazZg04kAM_6W6ZvumEdlb9HxCj1YQIj=w533-h800-no
Lf-C6M7QXgx0ZJL_SR_CrI-Tl8y_cCm56GCQIzkD2UrFopNedgiw7OSbsgI4HY91n8pvSuGlXM5aYaa0h3CPCln4yl6GUYHxV3QgTu_eh2qp1kcGLRRj9q3kVojWbQkhNj-jioHlzW5jmffW0yDdiTA8T4C57ljXQm13UU9wd0x2nCHyNgvOvAapN2eC2wFUMX0LQfHjBo7W2EIc1_7T8zSHMEZuP0YQZyqyqPws5Zf3Zi-KXjbJ9rr1XCUIZLKxLdg0prFav8AgCByG7tqYUXttI1WXj2v98CSu1rroD30RMdDA4q3h5lnzPUF33ay52ubifDciheMB3SagGaKerEKIYPb6qHzdHDE0VQJ6ctsHr3Fc6tSqEv8nJ2m_pJotGPY8CuU6Zsjozx-jcfPypP-5tHbxjdn0oH2y2tsyD76q2o5EixbbqnIPxaA0_U3U9mgi61wZOKJW5vV8txLSzTJp62_UcwQVJsxiBc_lku1jx5yjtdI9_ltpkR3gKnSASikiFf40WpcJxpUTM3aFXn2ckxHZNQBxl-eRIqo5_ZuP1tvDT2RJ8px0Sy_jrxSkkjmeMIXM99YF47iIZ6lCP4hXIKBZH-9N_PeD7RRqIM9jyNo-cF6GDD4R9by2V6uaYYYoyT5n1QGd1JLm-pQgazbZ_aFHLOuo4EVg=w800-h533-no
Performance-wise, I am very happy with the wheels. The new package is about 1 lbs lighter than stock despite being much wider. (1.5" wider wheel & 20mm wider tire) I can't say I can feel a noticeable difference in terms of actual acceleration, but I will say accelerating feels somehow smoother and more natural. The wider wheel, tire, and track width are also obivously contributing to a far more stable ride, and the vehicle's body doesn't roll nearly as much even though there are no suspension changes.
l5U7JR_C2SutsQFbKAGilPsnoh8ctDLdDsZgQYE9NPdicGHR0VUEpHn_vSS4XNiayIsS_744qANRIzb0QQQxB6kyGnwx9w9VEW7CstuHYg9QuL_Xh3WyLQGV7XqCPE3ST3qQhgQ-mCK8uDQtJ81AkzXWN1aDCKzuEgghoXSlNfpklkYYlssg7utFQ-G2EShHiWWp3sGXrruFrcQ7BWQh7tehzCGdnzXtuVMhvDjLSxB9uya3drv_9b6eoi8JCUcDk1-4v9ly4x62cwwj3Q-dqpNN3_uR_py-friVr1yR9ubU4iP6HPGRyPwJuljYWk4qrXiUY_NyMPGBgQiw_618lUugDBY4BVLcGKJLaDzo0BN3Rkba_4Y6VT4G9seQXAtcfJZMxmTmkj05CiYw4dsKU4gsMBjKEAwQlyJ6BpCS-6N26puc6gGogBut11PZB80OdxPFXBnLPs2Rl-WhwQ8vbXk1EiRioqfpqlCXPXZEWUnBA_QnZmzRxct48BXJ2ET52qu3GLDIdwY_x1o-oaEwvjiDEoY9OXmXjM1Ls7W2gKTNntV0zF9H4JFOC0IwAp6izG4UHTFeH6SCimbIO3jcQbXJiM3A-8tfGrBNoV_FOvU=w800-h450-no
Cosmetically, I have a somewhat mixed feeling about the wheels. On one hand, the looks, colour, and finishing of the wheel is top notch when you are looking at the outward-facing side. On the other hand, the back side of the wheel is a little more disappointing. As illustrated in the photo, some of the finishing on the spokes leave a bit to be desired. Not only are there some rough edges on some of the spokes, the thickness of some of the spokes are also not uniform on the backside. I cannot tell whether the slightly uneven spoke thickness is a result of the casting or the painting process. But I know from experience that my Enkei PF01 has some practically flawless surface finishing everywhere across the wheel. The difference in finishing quality is hardly surprising though -- the Enkei is about 2x more $$$ than the Konig in a similar size, and the Enkei is made in Japan, whereas the Konig is made in China.
Still, I am a happy GWR customer, and I still think the purchase was a fantastic one.
