I have a 2019 cx5, and I just took it to a body shop to repair some dents and scratches on the passenger side door and front fender. Car did not have this error when I turned the car in, but once I picked it up from the shop, I have this error on the dash.
Symptoms of the issue are that I cannot use the button on the outside door handle to unlock the doors. Also, the automatic lock when I walk away from the car does not happen either.
Before I go any further, does anyone know of any fixes? Just googling the that dash error, a lot of people have mentioned checking the fob and car batteries (both are fine), and then disconnecting the car battery to reset the car ECU. It seemed like no one really knew what was going on and just throwing suggestions out there. Of course, no one who encountered this problem reported back whether any of these proposed fixes actually fixed the issue. That said, I disconnected the car battery for an hour since it was the only consistent suggestion, and yet the issue persists.
I checked for codes on my OBD scanner and it gave me "B1210-1F" which, after googling, seems to be some short circuit in the keyless entry system.
More googling found this 2014 Mazda 6 troubleshooting guide specifically for that error code. I also found this keyless antenna removal/installation guide for the CX5, but not in conjunction with the error code.
Is there a place I can check error codes online where I can get CX5-related troubleshooting? Or can anyone confirm that the CX5 service manual link I posted even what I need to be doing to hopefully repair this?
Or, ignoring any of my own research and leading questions, does anyone have any suggestions for how to fix this issue? Dealer is an hour away, would like to avoid going to them. Also, not sure whether the body shop I worked with would know how to fix this, or whether it's worth it to go back to them and ask them to help fix? Many thanks in advance for any suggestions you can provide
