Joint Shaft Bearing?
KMac
Zoomin' since 2003
Mazda Protege5, 02
I have looked in the how too section about this bearing and am really not sure what to do. I can pull the axles etc. etc., but wanted to know what the darn part name would be for replacing the joint bearing. Looking at Rockauto.com I can find the drive shaft bearing which I believe is the one right at the case but what about the Joint shaft bearing which is it. The P5 Maintenance manual the bearing is separated using the SST but what is the bearing to buy? Any ideas?
