I just installed the JBR "complete shift kit" which includes the weighted handle and the short shift plate and block (all hardware included). Installation instructions on the website were spot on and I just took my time and followed them (not like me). Everything went fine as far as that goes. The most difficult aspect was tightening the plate and block together "evenly" since there are only three bolts making a "star pattern" impossible. I got the farthest apart ones down snug, tightened the "middle" one then continued the pattern until all was tight.
In terms of feel, lateral distances are maintained (the selector is not affected by the plate installation) the kit only affects fore-aft shifting distances. I'm not sure I'd try this kit without the weighted handle; as expected the engagement is a bit more difficult. With the handle it's well balanced on gears one through four. Going to fifth is stiff though. I'm hoping a fluid change later this year will smooth that out a bit. But, again, 1 - 4 is nice. Despite fifth, reverse doesn't seem to feel too much different, but that one was always a little stiffer than the rest so maybe I just expected it so it's less of a surprise.
My only only negative is the shape of the knob. I would have preferred the top where it crowns flat to the pattern area be rounded smoothly as opposed to the trapezoid profile. It would be more comfortable. It's not terrible, but it's not ideal either. I like the crinkle black finish (look and feel) and the weight makes shifting and even makes the whole car feel both upscale and sportier. It's amazing how little things can affect your overall impressions.
I'd do the plate again as opposed to a "real kit" as I think I've gotten as much out of this trans as I need, but I think I'd look for a different weight knob, something with a smoother, rounder shape even if that means it would be a little more "traditional" or "boring".
